Carb issue i hope
Discussion in 'General Maverick/Comet' started by x72COMETx, Mar 31, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    For the past week my engine has been running like garbage to were i cant drive it, it jerks and hesitates like its not getting fuel, the carb that is running on it is a road demon 600 and it only recently started running like this, i checked the plugs and they were a bit pinkish black so i cleaned them and installed them no change so i installed another carb i have which is a 750 summit 4 brl and the problem was still their, so i pulled that carb off since i didnt want to run that big of a carb on my setup for too long and pulled the plugs again this time they were black so i bought new plugs installed those and through the 600 back on and it ran fine at idle but after a few min of driving the problem is starting again, i do not no much about carbs so please be very descriptive thanks
  2. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    If your plugs were black that means the carb was very rich. Is your ignition system working properly. If you still have points are they adjusted correctly and was the timing set after the points were set?
  3. junrai
    junrai Member
    rancho cordova ca
    so you have points or a more modern ignition system? if you have points check them make sure theyre making spark and check your coil.
    Im leaning towards something in the ignition system check to see if you have any loose wires
    I dont think its your carb since you changed it and got the same results the plugs being black is carbon or left over gas meaning its running very ruch like youre getting a weak spark or none at all at times
    I cant say for sure without knowing more about your car
    hope this helps some how
    I car did that recently and we come to find out the gear on my distributor was coming loose as the pin that holds the gear on teh bottom of the shaft was cracked and allowing the gear to move around a little causing me similar problems especially when I tried to get on it
  4. Hotrock
    Munroe Falls, Ohio
    So the problem is not the carburetor. Do as junrai suggests next.
    71gold likes this.
  5. x72COMETx
    x72COMETx Member
    Vallejo CA
    Yes i have points and they were adjusted after the timing, im thinking about going electronic,
  6. JL Mav
    Douglas county NV
    You need to adjust the timing last as points adjustment will change the timing. If you have a adjustable timing light you can see if the timing is moving erratically when the advance is all the way in. (revving from 2800 - 4800 rpm there shouldn't be much change.)
  7. mojo
    Might be a fuel pump issue!
  8. Hotrock
    Munroe Falls, Ohio
    Or old rubber fuel lines or in-line fuel filter.
  9. Hotrock
    Munroe Falls, Ohio
    Don't even consider going to an electronic system until you get your problem solved. The issue may not be the ignition system.
  10. x72COMETx
    x72COMETx Member
    Vallejo CA
    Ya im going to try a carb off my brothers comet that i no works so hopefully it will be the carb
