Carb question....
Discussion in 'Technical' started by CornedBeef4.6L, Apr 26, 2006.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Do holley and edelbrock carbs have the same mounting bolt pattern. I have never used an edelbrock so i am clueless......This is not an aftermarket intake so it will only have one set of bolt patterns which as of now has an edelbrock. I am trying to help a fellow board/club member out. Any info would be appreciated:29:
  2. don graham
    i have never used an edelbrock carb. but i've used a lot of edelbrock intakes. i've always used a holley.:) can't imagine them making the intakes and not being able to use their own carbs. i'm sure someone knows for sure. if not give edelbrock a call.
  3. CornedBeef4.6L
    no longer here
    yea but they have 2 bolt patterns on the edelbrock intakes which is where I am confused
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    there is a line of edelbrock carbs that use a diff bolt pattern. cant remember how they are differentiated by name, but the majority of intakes and carbs made by edel use the standard size bolt pattern and sizing. not sure if that helped you any.
  5. don graham
    i just went out and checked the torker II intake for a 351w and it only has one set of holes, but my torker II for the 302 has both sets. :huh:
  6. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Lance, yes they do. Provided that neither one is a spreadbore.
    btw. i'm 99.99999% sure that the edelbrock has a dual bolt patern anyway.(y)
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    There is a Carter (aka Federal Mogul, aka Edelbrock) that uses a different pattern.
    However, the Federal Mogul carbs that Edelbrock sells with it's name on them all use Holley patterns.
    Does that make sense? :huh:
    If it is an Edelbrock based on the AFB, then it fits.
    If it is a Carter, then it may or may not unless it is an AFB.
    The other bolt pattern commonly put on Edelbrock intakes is usually the Q-jet pattern.
    Dave
  8. Earl Branham
    Lugoff, SC
    I removed an Edelbrock from my car, using an Edelbrock Performer 289. Bolted right up with no mods or problems. The accelerator cable snapped on with no problems.
  9. courier11sec
    courier11sec Member
    Tucson, AZ
    They have the same bolt pattern unless one is a spreadbore replacement. If that's the case, pitch it over your left shoulder.
