carb rebuild
Discussion in 'New Members Forum' started by lovnmymav, Nov 17, 2012.
  1. lovnmymav
    lovnmymav New Member
    Richmond,VA
    1976 Ford Maverick
    Hay I am new to this forum and I just got a 76 maverick. In line v6 250 with a one barrel Carb. I have noticed that the carb is leaking from all the gaskets so I want to rebuild it but I am having trouble identifying the Carb to go buy a kit. The number on the Carb is 62253 carter. I've never done this before so any help is welcomed. Thanks mandy
  2. mav1970
    Have you tried ordering a kit using the Carter number that you have? Years ago, I would rebuild my own carbs. The instructions were pretty easy to follow and a Chilton book helped. The main thing is to have a way to clean off of the parts. I remember buying a carb cleaner kit the size of a Crisco can that had a little basket for soaking small parts in. It also helps to know someone you can have double-check what you've done or help with adjustments. Most counter men these days never saw a carb so the carb experts are dwindling. :)
  3. Red1972Grabber
    Northern California
    Welcome from Northern California! :chirp:
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  5. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Welcome ,go to google images and do a 1 barrel carter, carb image search. Then you could ask more questions .:tiphat:
  6. lovnmymav
    Richmond,VA
    1976 Ford Maverick
    Thanks for all the warm welcomes and advice.
  7. 71gold
    :Welcome: :Handshake
  8. MistaVista
    MistaVista Member
    Sun City, CA
    1974 Maverick 1970 Falcon Futura 4 dr.
    :Welcome: to the site...
  9. Acornridgeman
    Wisconsin
    Look like this?
    Carter RBS
  10. lovnmymav
    Richmond,VA
    1976 Ford Maverick
    Here's some pictures of it I took this morning.
  11. Acornridgeman
    Wisconsin
    That is a Carter YF - very easy to rebuild and the kit can be bought at any parts house for around $15.
    As mentioned earlier - there is a gallon size can of gunk parts cleaner that comes with a little parts basket and will allow you to soak all the parts for a few days.
    Or, you can buy a rebuilt carb for around $100 and just bolt it on. If buying a carb make sure it has the bigger bore for the 200, as there is a smaller version for the 170.
    :Welcome:
  12. lovnmymav
    Richmond,VA
    1976 Ford Maverick
  13. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
