Carb Size?
Discussion in 'Technical' started by stangman99, Aug 7, 2002.
  1. stangman99
    stangman99 Member
    Colorado Springs
    74 Maverick
    I have a 74 Maverick 302 V8 and would like opinions on what carb size to go with?
    I will be using the Edelbrock Preformer manifold. The only other changes I will be making are headers & electronic Ign.
    Thanks:D
  2. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    500 cfm Edelbrock or 600 Holley vacuum secondary, no larger. Stock 302 at 6000 rpm and 100% efficiency only pumps 575 cfm so subtract 20%, from that yet.
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I would go with the Edelbrock carb at this point. They really seem to work well.
  4. mavman
    mavman Member
    Arkansas
    stock engine, street car, go with the Edelbrock. Much easier to deal with, set the idle mixture screws, and leave it. THey hold a tune better. If it's something that you dont mind messing with occasionally, a Holley is the way to go. They will make more power, but usually require some attention occasionally. Either way, on a stock engine, I would think a 600 would be plenty, mostly because they're the cheapest available. There's no such thing as too big of a carb if you think about it....at 3000 rpm wide open throttle at 100% efficiency, a 302 only needs 262 cfm. In theory, a 600 would be too big at that engine speed.
  5. stangman99
    stangman99 Member
    Colorado Springs
    74 Maverick
    thank you for your replys gentleman, I have been out of this trickin stuff for a long time and have forgotten quite a bit! Stage One for this car Is minor mods. Then I will move on to stage II
  6. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    tip
    To determine the cfm, take the engine size in cubic inches and multiply it by the maximum rpm or your engine then devide it by 3456 .
    Vacuum secondary models for cars with street gearing and an auto tranny .
    Mechanical secondary models for strip gearing and a manual tranny
  7. K. Brock
    K. Brock Member
    San Antonio, TX
    1977 Mav, 2dr, p/s, p/b, 302 w/tremec 3550
  8. 357 Grabber
    357 Grabber Maverick DieHard
    kentucky
    2 71 grabbers,72 Maverick , son has a 73 maverick
    If you go with a vac secodary 600 cfm holley the rear of the carb will be too lean @ WFO..I got a 700 DP before I switched to the windsor. if you mash to the floor and secondarys engage...lift lightly on the throttle and the car will pull harder..you can get bigger metering plates
