Carb swap over
Discussion in 'Technical' started by Ol Maverick Man, Mar 16, 2012.
  1. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I have a 750 dual feed, vacuum secondary carb. I located a body from a 600 cfm carb. Can I swap just the body of the carb to make it a 600 cfm using the 750 base and bowls.
  2. Joe Dirt
    No, it wouldnt be a 600cfm more like a 670 and some work will need to be proformed to the main body
    Why do you not want to use the 750?
  3. Ol Maverick Man
    Wallingford, Ct.
    I am running the the 750 now. On paper it is suppose to be too large.
    I have to admit it is running good.
  4. Bryant
    the vacuum secondary will cancel out the to bigness of the carb. the secondarys will only open how ever much is needed.
