carb
Discussion in 'Technical' started by loki1911, Apr 10, 2007.
  1. loki1911
    loki1911 Lucky
    Milton, WA
    '73 Maverick soon to be grabber clone
    when it comes to edelbrock carbs, thunder avs or performer? performer rpm manifold, trying to get around 400 horses...dart windsor jr heads, comp cams 274... also im trying to decide i can get it as a kit with an 800 cfm thunder or i could buy them individually and go with a 600 or 650 what do you guys think???
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You'll need more cfm than that to make 400 horses...
  3. loki1911
    loki1911 Lucky
    Milton, WA
    what would you guys recommend for carb and manifold for the other parts i listed?
  4. loki1911
    loki1911 Lucky
    Milton, WA
  5. T.L.
    T.L. Banned
    Southern Colorado
    Holley Street Avenger 770...
  6. stmanser
    Davenport, Iowa
    i would say that the RPM intake or an AIR GAP intake and a 750 double pumper or equivelant
  7. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Throw the Edelbrock into the street, run over it on the way to the speed shop to buy a Holley 750 dp.
  8. loki1911
    loki1911 Lucky
    Milton, WA
    i was wondering about edelbrocks beause im completely new to tuning carburetors and all of that fun stuff and ive heard edelbrocks were more user friendly
  9. loki1911
    loki1911 Lucky
    Milton, WA
    and would you recommend the rpm or air gap manifold?
  10. togetic2002
    togetic2002 Member
    Reno NV
    72 sprint(major reconsruction),92 5.0 ho t-bird
    noooo dont run it:naughty: over send it to me (ups) ill put it back together after there done with it:D
  11. PaulS
    If you are running a 302 with a 274 comp cam you won't get enough duration to get 400 HP. With that cam you will only allow the engine to breath well to about 6200 RPM. You might get 350 HP from a 302 at .030 over bore and 10:1 compression. Putting a bigger carb on it is not the answer.
  12. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Yeah...about as user friendly as a rabid doberman.
    I'd run either manifold. Not a huge difference between the two. And, for the money, the Weiand Stealth is a damn good intake also.
  13. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't know if that is enough manifold, or cam, to get 400 horses out of a 302.
    Now if your running a 347, or any 351 version, you're probably okay.
    Dump the idea of using a Federal Mogul carb and go with a Holley.
    I'd use a DP Holley. Probably a 700. I like that one for it's extra little perks over other DPs.
    That cam could do much better if it had an intake to match it.
    The RPM is just a compromise between high and low rpm power, not the best. If you want that kind of HP from small cubes, you do not have the luxury of compromise. If you still insist on limiting yourself to a dual plane intake, I like the Stealth better myself.
  14. ratio411
    ratio411 Member
    Pensacola
    You haven't said what engine size you are working on...
    I ran a 306 through the engine model and came up with:
    321 FWHP and 314# FWTQ
    98% VE
    EDIT:
    The graph shows a pair of lines for a less powerful engine.
    Those are the graph of a STOCK 72 Maverick 302 engine.
  15. ratio411
    ratio411 Member
    Pensacola
    I added a Vic Jr intake. NO OTHER CHANGES.
    It added:
    20# TQ
    25 HP
    5% VE for a total of 103%
    Edit:
    GT40X heads (inexpensive aluminum)
    Added another:
    40# TQ and 43 HP with 109% VE
    389 FWHP at this point.
    Still playing ;)
    Just for giggles, I installed AFR 185s.
    417 FWHP and 114% VE!
    And that was still without changing any other stuff to match the heads.
    I believe I could keep the short block, cam, and heads the same and still add a bunch to that 417 by swapping intake, carb, headers, mufflers, etc...
    This thing is still running 6901 headers!
