Carbon build up on valves
Discussion in 'Technical' started by LEATHERFACE, Mar 26, 2011.
  1. LEATHERFACE
    LEATHERFACE Member
    Union Valley, Texas
    1964 Mercury Comet Caliente
  2. Joe Dirt
    ive had better luck with gm top engine cleaner its cheap and works wonders.
  3. darren
    Used the Chrysler combustion chamber cleaner for years. It works really well. Saved me countless head R&R. Had a Dakota 3.7 2 weeks ago. Plugged left Cat converter. Replaced cat but steady misfires number 3&5 cyl. Figured it might have burned a valve or 2. Checked comp. and it was high on that bank. Ran 2 cans of CCC. let it sit a few hours then drove it hard, lots of good decels. Got back to shop. Not a single misfire counting on the scanner. Proof positive once again how well CCC works for us.
  4. injectedmav
    injectedmav Member
    Georgia
    Ford's liquid carb cleaner that you pour in, not spray, works pretty good too. Same process as above. As the carbon breaks up, it will go through the engine(valves) so it can stick them open during the process. The combustion is usually cool enough to not actually burn the valves so you should be ok. I would also change the oil afterward. Good maintenance to prevent it from happening again is important and I've had good luck with BG44K, and Techron from Chevron is proven good stuff too.
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    I've done the water trick before.
    Works better than you'd think.
  6. 72MAVGRABHER
    Roanoke, Va.
    ^^^^ several times. water trick works well. dont pour too fast obviously, or it will stall.
  7. Streamliner
    Streamliner Member
    I remember my shop teacher telling us they used to dribble Coca-Cola down the carb while running:huh:
  8. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    ive run octane booster through mine for little while and it actually helped more.
