carburetor
Discussion in 'Technical' started by Lord Tone, May 8, 2015.
  1. Lord Tone
    Lord Tone Member
    '74 ford mavrick
    i have a new carburetor on my 74 maverick i got it to start fine, but it refuses to idle ???
  2. 71gold
  3. Krazy Comet
    More info needed... Does it idle too slow, rough, etc... Vacuum lines hooked up and correct, timing in spec? Tune up items(plugs, wires, etc) OK???
    Lord Tone likes this.
  4. Lord Tone
    Lord Tone Member
    '74 ford mavrick
    honestly its in need of a tune up and the vacuum lines are not hooked up correctly. know were i can get a diagram of the proper setup (i bought it yesterday)
  5. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
  6. Lord Tone
    Lord Tone Member
    '74 ford mavrick
    Thanks guys, really apreaciate the help :urock:
  7. Lord Tone
    Lord Tone Member
    '74 ford mavrick
  8. 71gold
    what carb?
  9. baddad457
    Once you get the vacuum hoses figured out, start it up, get it to idle, then set the initial timing, if that calls for 6*BTC, set it to 10-12*BTC, the engine should like the extra timing lead. Then go back and set the idle at the throttle shaft, then fine tune the idle with the mixture screws. What ignition are you running ? (points, electronic ?)
