cast iron v.s aluminum heads
Discussion in 'General Maverick/Comet' started by bLaH_hA, Oct 9, 2009.
  1. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    i mean yeah you gain more horsepower with aluminum but i was told aluminum is risky but i am not sure.
    I have a extra 302 block that i want to make it a boss clone but i want to get all the facts straight before i do any advancements
  2. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    btw i am not looking to race this engine it will be a daily driver and sometimes hit 90+ on the bucman lol
  3. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I'm not currently running aluminum heads but there's alot of them running around here. Not to mention all the newer stuff runs them. From what I understand they're alot less tolerant of overheating, so as long as your cooling system is up to par you shouldn't have a problem.
  4. Mavman72
    The main reasons to go to alloy heads are for the weight savings and the better breathing characteristics.Improved port shapes/volums and chamber design along with valve size choices.You can usually run a full point more compression on pump gas with em too since they tend heat evenly and and are less likely to develop hot spots which can cause pre-ignintion.
  5. 71gold
    ...stock 302 w/iron heads...they have been doing this for years...:yup:
  6. maverick maniac
    maverick maniac Banned
    owensboro ky
    I am just old school and if you can find an early set of windsor heads 70 -74 I would run those instead of allum. thats what I got and they are less money to,, thats my 2 cents
  7. Jamie Miles
    My aluminum headed 302 has been together since 99, and still runs awesome. If you've got the money, go aluminum.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I could have gone with aluminum heads, but didn't. After I spent about $700 on my 351W heads, I wish that I had. Mine run well for a street/play car, but with only s/s larger valves and milling the combustion chambers, I am probably short on HP and torque compared to out of the box Edelbrock Performer or similar heads.
    On the flip side, I may have been less likely to mill new aluminum heads to up my compression. My motor guy told me that Performers stock woulkd have yielded about 9-9.25:1 CR. Milling my 351W to 53cc chambers yielded a little less than 10.5:1 CR.
    The flow of aluminum heads may have equalled that CR difference??
    As previously stated, aluminum saves weight, and dissipates heat better.
    Seth
  9. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    it wasent the flow that made the compression difference,it was the chamber size.
    aluminum heads are a TON better than they used to be.if you run aluminum heads you can run a point more compression like was mentioned,but use a good head gasket.most new engines with aluminum heads use mls gaskets that seem to stop from blowing out when over heated.
  10. maverick maniac
    owensboro ky
    what year heads did you use ?? I only have 350.00 in mine all new everything there are 1970 heads
  11. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    1970
    Mine were bare castings-stock supposedly. I don't have the breakdown, but after hot tanking, magnufluxing, cutting the bowls, S/S Ferrea valves, 3 angle valve job, guideplates, hardened valve seats, bronze valve guides, tapping & studs, milled to 53cc's, the bill was over $700. I'm probably including the $75 that I paid for the bare heads(if memory is correct).
    Seth
  12. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    I know that, I'm talking about the performance difference.
  13. darren
    Lets put it this way. If I had to build a motor I wouldnt waste any money on iron heads. I have set of 68 302 4V heads in the garage but I would still go and buy aluminum heads instead of spending money on machining and my time on porting.
  14. Dave B
  15. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Go alum, Ive got trick flow heads running 10.4 on the piston compression and absoultly no pinging whatsoever on pump gas,im making approx 400 hp..
