What would cause trans fluid to leak out of the front of the bellhousing? My only idea is, front seal leaking. Anything else? Newly rebuilt C-4. No, I didn't do it. Thanks, Jerry
Jerry, Possibly the torque converter drain plug, but I doubt it. Probably the seal. How much is it leaking? Later,
If it's the front seal, it could be caused by a bad convertor collar as that's what the seal rides on. Check that while you have it out.
