CB wiring help
Discussion in 'Technical' started by maverick656, Aug 3, 2013.
  1. maverick656
    maverick656 Member
    Washington Pa
    1975 Ford Maverick
    I am wiring a cb radio into my 75 maverick and I need to know where I should wire it to. The cigar lighter isnt putting out enough, as I need 2 amps and it gives only one. Any suggestions?
  2. baddad457
    The cigarette lighter has a thirty amp fuse. 2 amps drawing from it is nothing. You can wire a CB to virtually any circuit. Pick one.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    When I had one, I connected it to the Accessory terminal, which is switched by the ignition key.
