Center link drag link question
Discussion in 'Technical' started by heliboy, Oct 31, 2013.
  1. heliboy
    heliboy 76' Mav
    Frankfort, Ky.
    1976 Maverick 2 door
    For manual steering, is there any difference in the 70-74 center/drag links than the 75-77 ones?
  2. Krazy Comet
    Well for the P/S I know the '77 unit I'm using is beefier than the '72 and uses different idler arm, '77 has pin for idler in the drag link while the '72 has pressed in bushing... I went with the later unit as a complete idler is readily available... AFAIK idler arms are year specific, whether M/S or P/S makes no difference...
  3. Craig Selvey
    Yes, they are different. The 1970-74 pitman arm has a hole in the pitman arm to accept a stud from the center link. 1975-1977 is just the opposite.
  4. rthomas771
    70-74 on top...75-77 on bottom
  5. Craig Selvey
    Looks like they are orientated backwards to each other.
  6. Krazy Comet
    Agreed, which means the Pittman arms must be different as well...
  7. Torpeteo
    Torpeteo Member
    Traverse city mi
    1971 mercury comet
