Change front and rear sway bars???
Discussion in 'Technical' started by OG's77Comet, Apr 7, 2009.
  1. OG's77Comet
    OG's77Comet Member
    Brooklyn,NY
    1977 Comet
    Ok so I have been watching some front and rear sway bars, each set $115....Is it worth changing those? I know they are supposed to improve handle blah blah blah but all parts are advertised to say that. Also is that price for a set good?
  2. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Depends on what size they are and if they come with bushings. I'd get the biggest bars you can find. You don't have one in the rear if your car is stock, but I've seen aftermarket rear bars on here somewhere. That being said anything new is going to be a heck of a lot better than something that's been flexing back and forth for 32 years, myself included :D
  3. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
    New sway bars are definitely worth it. It takes a little drilling to install a rear one, but adding a rear and upgrading the front one makes the car handle a lot better. I got my set from PST and am really happy with it. It came with all the hardware and bushings. Not sure what it cost me though, I bought it as part of a bigger suspension package.
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    72CometGT what size are your sway bars?
  5. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
  6. OG's77Comet
    OG's77Comet Member
    Brooklyn,NY
    1977 Comet
    Ok cool, so I am going to buy the 7/8 fronts and eventually see about the back. I am not one to go drilling on the car I would have to find someone to do that.
  7. Craig Selvey
    Hey OG's77Comet:
    I thought you were thinking about selling the car because it needed so much work to pass inspection?
  8. OG's77Comet
    OG's77Comet Member
    Brooklyn,NY
    1977 Comet
    I was until I decided that I do want to learn about cars and fixing them and I did not want to give up so quickly without even trying to do the work myself. I found out a friend of mine is pretty good wit cars so he showed me how to change the rotors and caliper and I am going to be changing the two fronts, and looking for someone with some experience with shocks to change those. I have bought auto repair for dummies which is really good and the haynes manual for the comet which is also good. Once I started putting effort in I learned quite a bit.
  9. Craig Selvey
    I think before you start spending money on sway bars.....might want to save that money and spend it on other area's of the car first. Get it in tip top shape before you start adding performance and handling items like sway bars.
  10. OG's77Comet
    OG's77Comet Member
    Brooklyn,NY
    1977 Comet
    Sounds good. Thanks. Trust me, no rush here at all, I would like to change these calipers and rotors first. There is just so many questions so I ask them here being that everyone is so great and knowledgeable. My notebook is filling up.
  11. Craig Selvey
    You definitely need to make sure the brakes are in order. Then go after all the other things on you list that prevents it from passing inspection, like the suspension, power steering leaks, etc.
