I have searched the archives and had no luck on finding info. on a rotor swap. I have installed a mustang 2 front end into a maverick and I would like to have at least 10 1/2" rotors on the front. This is a 77 mustang front end with the rack mounted on the front not the rear. The reason I say that I have seen some articles where someone had said that the maverick disc can "somewhat" interchange with it, with some fabrication that is fine but the maverick steering arm is from the back And that won't work with my application
John, check out www.bigdogstreetrods.com They are in Maryland Heights, MO they have a 11" rotor kit with rotors, bearings, seals, calipers and brackets for $263
