Cheap carpet kits
Discussion in 'General Maverick/Comet' started by 7D2 Grabber, Mar 9, 2015.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
  2. 55crownvic
    55crownvic Member
    colorado springs
    I'd rather have that 2-piece kit as opposed to the one piece I tried to install in my 70, would be much easier to work with having seperate halves.
  3. 7D2 Grabber
    7D2 Grabber Member
    I bought a 1 piece as well and paid a lot more than what's posted. Would prefer a 2 piece
  4. 71gold
    Fits 1971 Ford Maverick Base 8 Cyl 5.0L
    • 1969-1977: Base; All Engines;
    ...:slap:...
  5. 71gold
    I'm getting ready to pull mine for a mod so that would be a good time for me to put in a new 2 piece...:Handshake:
  6. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    ......I must be different. I installed a "one-piece", and it went in fine, in my 1970.
    I removed all the seats, door sills, and plastic kick boards, and rear side pieces. I let the carpet "relax" a couple of days in the "pan" (on hot days), and then formed & trimmed. I used an old tip in my soldering iron, to make holes for dimmer switch, and seat-belt bolts. The melting process ensures that the tread/weave won't unravel.
    After laying in the carpet, you can guide the soldering iron tip from the underside of the car, through the seat-belt bolt holes, and make very clean openings.
    mojo likes this.
  7. 55crownvic
    55crownvic Member
    colorado springs
    "on hot days"????? Whats that like? Around here we have 2 seasons, winter and july.
  8. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Ok.....so you have to wait a few months. :biglaugh:
  9. mojo
    I wish I had know this trick when I did my carpet "1 piece". I never thought abt using a soldering iron to make the openings. So far, I don't seem to have an raveling. If I do it again - I will use the iron. Thanks for sharing...
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I've installed two 1-piece ACC carpets in my Maverick. The first one didn't fit great, and had the thick jute backing on the driveline tunnel part which made installation of the seats a real pain. The second one which is in there now doesn't have the jute in that area, and fits much better. The biggest fitment problem with the first one was the width was off a little bit and did not properly tuck under the sill plates.
    Knowing what I know now, I would also prefer the 2-piece, but did not see an option for that when I ordered.
