Cheap serpentine setup
Discussion in 'Technical' started by 7D2 Grabber, Sep 29, 2010.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I found out a cheap way to get a serpentine set up, some of you might have already done it. You should be able to get these parts fairly cheap. All you need is the pulleys and the stock alternator bracket for a 5.0 mustang.
    I had to use the 6pk1105 belt.
    All you have to do is reverse the belt tensioner which is in the link below. These are not my personal photos but it took me about 10 min do it. Remove the cap and drill the new hole 180 degrees from the pin.
    http://forums.corral.net/forums/showthread.php?t=1239573&highlight=reverse+tensioner
  2. Dave B
    Nice! Thanks! (y)
  3. Bob Wiken
    Fayetteville, Arkansas
    I believe you'll need to change the water pump to a reverse rotation pump
  4. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    Will this work on my '74 302? Are the part #'s available? I'd love to do this in conjunction with an electric fan swap.
  5. lastchance
    lastchance Member
    Hingham , Massachusetts
    Check the pictures real close ,the water pump is running normal rotation. Nicely done.
  6. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    my only concern, it looks like your running the grooved side of the belt on a flat pully.
  7. darren
    ITs running reverse rotation(late model) and it looks like the tensioner is running a flat pulley on the grooved side of the belt. Is that correct??
  8. darren
    Unless I have different pics you may want to look again.
  9. bmcdaniel
    bmcdaniel Senile Member
    Easier way is to get a grooved serpentine water pump pulley from a late-80s Crown Vic, no need for a tensioner and keep the standard rotation water pump.
    Or use one of these
    http://www.summitracing.com/parts/ASP-820021/
    This pulley is actually cheaper if ordered directly from Auto Specialties rather than Summit.
  10. 7D2 Grabber
    7D2 Grabber Member
    Pump is reverse rotation, when i bought my roller shortblock it came with an edelbrock pump. Instead of getting rid of the pump and investing with into a standard pump I just bought the alternator bracket w/ tensioner. I guess alot of the 5.0 guys run this setup when they remove the a/c, smog and p/s. I also put my 3g alt at the same time so i didnt have to remove my alt pulley. Like the first post states these are not my pics, i'm just showing how the belt is being routing
  11. mean_maverick
    the only downfall to me is the fact that this setup has a full time tensioner versus the older "lock and clamp" style adjustment on the alt bracket
  12. lastchance
    lastchance Member
    Sorry Darren I was wrong.
  13. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    How would it work and look (pic) running AC and no PS?
    Rick
  14. flynbrd
    flynbrd Member
    Your lucky the belt doesn't slip on the water pump under high load. I thought the rule of thumb was to have at least half the rotating body covered by the belt. From the pictures it appears only about 1/3 of the belt is making contact?
  15. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Someone educate me---what's the advantage?:huh:
