Check out this fit
Discussion in 'Technical' started by Mavaholic, Aug 26, 2007.
  1. Mavaholic
    As you may recall, I picked up a 2002 Escort power brake booster to modify for our cars. Well, I got around to at least getting it to fit. As you can see, it fits pretty damn good with little modification to the engine compartment. It still needs to slide back another 1/2" or so but it is hitting the brake pedal mount somewhere. Hopefully in the next week or so I will get the dash out so I have full unobstructed access to the pedal mount system to see what it will take to actually mount it. Its looking like this is going to be a good swap though. I will write a full "How to" when I am done. Stay tuned!!!
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Looks like a nice fit!
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yup,, looks like a fit to me.
    Dan
  4. Jamie Miles
    What would be the advantages of using this setup over the Geo Metro setup?
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Well for starters, it's a Ford part. :D
  6. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Did you make that custom bungie bracket yourself??? I've been wanting one of those forever!
    Cool job!
  7. Mavaholic
    I figure 2 bungees should be all I need for a permant mount. :D Dont know about the GEO. It is smaller than this one.
  8. dtb147
    dtb147 Member
    Arbutus, MD
    How is the fit with the shock tower brace in place?
  9. scrapper60
    scrapper60 MCCI Member
    Alabama
    Is this going in an original non pb car? Looks good so far, Dennis.
  10. maverick1970
    Missouri
    That mount will give a nice soft peddle feel! :D
  11. Mavaholic
    Yup. Also a manual shift car so it has to clear all the clutch linkage. The stock shock tower brace will fit.
  12. signal20
    signal20 Paul VanSteen
    Spring Hill, FL
    The booster looks like its hitting the wireing harrnes plug.
    Or does the bungee mount allow for removal.:)
  13. Mavaholic
    I had to trim the corner off the plug. But there are no wires in that corner anyway.
  14. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Could something like this be done without removing the engine?
  15. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
