Check the lash on my exhaust valve !
Discussion in 'Technical' started by flynbrd, Sep 20, 2014.
  1. flynbrd
    flynbrd Member
    I love paying professionals to assemble my motor. Just check out the awesome job the shop did on my exhaust rocker.:dead: No wonder I had heat issues. Time to take the engine apart and look for damage.
  2. Dave B
    WOW!!!!! :shocked: That'll pound the valve stem nicely...
  3. scooper77515
    Meh! 1/4"...it will go away as the engine warms up.
    :dead:
    Check the lifter and cam lobes.
  4. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I would guess your losing the lobe.
  5. baddad457
    I'd guess the same if he's running a flat tappet cam. In which case the builder is not wholely responsible. It really is up to the guy who installs and fires up the engine to insure everything is done right before starting it up.
  6. flynbrd
    flynbrd Member
    Got the intake off with the heads, turns out its the lifter. Its a roller cam so I figured the lobes would be good. I'll post a pic soon of the collapsed lifter.
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    At least it is not a whipped out cam lobe..... Hopefully that's the only one you have a problem with.....
  8. scooper77515
    Did it not pump up? Or did the spring fail?
