Checking CAM wear
Discussion in 'Technical' started by penguin662, Oct 21, 2008.
  1. penguin662
    penguin662 Member
    North Augusta, SC 29860
    72 Comet GT
    If I remove the intake can I verify the condition of the CAM on a 302?
    As always thanks for the help!!!!
    Bob
  2. 71gold
    if you are trying to check to see why your "valves will not close"...it's not a "worn cam"...
    Cost for valve job
    Frank
  3. PaulS
    In order to check the condition of the cam you need some very expensive tooling.
    Micrometers can check the cam lobe height and bearing journals but there is a taper on each lobe that is difficult to measure and to find the rate of rise you need a recording indicator fixture that will rotate the cam and record each lobe's profile. Then you can check it against the cam's specs and see if it is within tollerances.
    You can make a good guess by examining the lifters though. If the lifters have any cupping on the bottom (where they ride on the cam) then the cam lobes are also worn. The lifters are not supposed to be flat - they are made with a slight dome that mates to the cam's taper so they spin in their bores instead of sliding against the cam.
    If you have any question as to the usability of the cam after inspecting the lifters then replace both. It is cheap insurance.
  4. scooper77515
    Cams are cheap...if you are worried about it, put in a bigger one. Be sure to swap springs on your heads at the same time.
  5. PaulS
    If you are going to add more lift or change to mechanical lifters be sure to have screw-in studs installed - the heads will have to have the stud bosses milled to accept the new studs.
  6. rthomas771
    Might as well get guide plates too and get rid of the rail rockers. Rail rockers are known to break with performance valve springs
