Cleaning turn signal switch
Discussion in 'Technical' started by mike75mav, Mar 9, 2014.
  1. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    As anybody cleaned the contacts on the turn signal switch with brake cleaner? I'm having problems that the blinker is not blinking. I replaced the blinker relay and the turn signal switch.
  2. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
    I replaced mine with one from ebay, actually had to do the steering wheel tube and got a NOS one.
    http://www.ebay.com/sch/i.html?_trk...averick+turn+signal+switch&_sacat=0&_from=R40
    They're pricey though...
    Have you tried light sanding them with like 1000 grit paper?
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    I haven't tried sandpaper yet. I did replace the switch with another one.
  4. Dianne
    Dianne Member
    Nampa, ID
    Use 1000 grit or lighter :)
  5. Rasit
    Rasit Member
    SE Pennsylvania
    I would use this instead of brake cleaner...
  6. Krazy Comet
    Yup, brake cleaner can melt/deform some plastics...
    There is a product called Deoxit that is supposed to be the best electronic cleaner avail, but is hard to find... The antique radio, guitar amp, etc restorers swear by it...
