close up 351 shots
Discussion in 'Technical' started by 289, Dec 8, 2013.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Anybody have any good close up photos of a 351? ive been looking around and not getting anything good. i just want to see the clearances with the tower. thanks.
  2. Mavman72
    Heres a few...Hope they help you out.
  3. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    You would think someone would take the time to do a ste up on headers that would fit better. Way to close for comfort.
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    there are headers out there that "fit better".. but they bend too hard coming right off the flange when doing so.
    Of course it depends on what rpm you want to squeeze out of a motor.. but I'll take headers that rub and cut my fingers when changing plugs.. over ones that don't and end up hurting flow potential any day. Just not enough room to have much cake here. Much better than manifolds though.. so there's that. (y)
  5. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Thanks, long tube headers? I see you had to dent the tubes in a little bit to fit in the tower. How much modification around the steering box?
  6. Mavman72
    No mods around the steering box...I didnt do the "denting" The gorilla who did the swap (very poorly I might add) made the dents. I would have done it differently If I were the one to do the swap.
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Crites makes headers for the 351w motor,you have to do a few mods to get them in but they work(1 3/4 tubes).Does anyone know if you can get a short oil filter to go on the 351,as the fl1a won`t fit because it`s to long.I really don`t want to run a remote & the shorter 1 won`t hurt me on a race mtr because I`ll be changing the oil a lot anyway.
  8. John Holden
    John Holden Member
    NJ
    Those Crites headers probably won't fit a 302 huh? Maybe with spacers?
  9. mav1970
    Wow is that congested - my Cleveland was tighter but a different engine all around - just wish I had cut back the towers on my original build :)
