clutch cable insulation
Discussion in 'Technical' started by streetrod77, Sep 8, 2008.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I need some sort of insulation for my clutch cable. I had to route the cable down by the headers, just was not long enough to go around.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Both sounds good. Were can I get shifter boot insulation also. I guess I will need that too now that I have cut a hole in the floor for the stick. I didn't think about that.
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    "Shifter Boot" insulation??? Did I really say that? :hmmm:
    I meant to say Spark Plug boot. They are available at most auto parts stores.
  6. rthomas771
    Has anyone used a hydraulic clutch set-up on their Maverick? To me that would be the way to go. No more burnt, stretched or broken cable.
  7. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have all the parts that go with a T5 but I got all the parts for the cable 1st, so I started with the cable. If this does work or is problems than I will try the hydraulic way. If the cable works, I will just sell the other stuff. I think you are right though. Cable just needed less parts to work. I did get a firewall adjuster, so maybe that makes a difference.
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
