Clutch / Throw Out Bearing Replacement
Discussion in 'Transmissions' started by Wright712, Oct 1, 2009.
  1. Wright712
    Wright712 Member
    My Maverick whirs when I press the clutch. So, I think the throw out bearing is going out. The Maverick is also a little choppy before warmed up when accelerating from stop in first gear.
    I'm in the military and have access to the garage on base. They have lifts and all tools. They also have some knoweldgable mechanics who are willing to assist. I don't mind getting dirty, but I've never replaced a clutch before.
    Should I buy a clutch kit and replace it all? Or should I only replace the throw out bearing? Or, should I pay someone else to replace it?
    Thanks,
    Jason
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    it is a pretty easy lod to do with the correct tools and some basic mechanical
    exper. and wow a lift (you lucky dog) that will make it even easier ..by all new if you can afford that way your good to go .
  3. Bryant
    it should be really easy. for instructions we need to know about your car.
    what type of motor?
    what type of trans?
    what does it have for an exhast system?
    does it have a floor shifter or a colum shifter?
  4. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    If your going in side the bell housing replace it all with good stuff and don't forget the pilot bearing ....
    JAY
  5. Mavman72
    May want to get the flywheel resurfaced as well.Especially if it looks like an old brake rotor. Its good insurance against a chattering clutch.
  6. rthomas771
    Yep...I put an Autozone clutch kit in my 85 4x4 Ranger...it lasted 3 weeks before the pressure plate came unglude. I got to do two clutch repairs in one month. Too much work to replace it again with the same cheap kit so I bought a real clutch kit from Ford. I waisted money on the first kit trying to save a few dollars.
  7. Wright712
    Wright712 Member
    Thanks for the assistance, guys.
    I have a 1970 with 200 ci motor and 3 speed manual on the column.
    I was looking at buying a clutch kit from either Napa or Carquest. Napa is about $40 cheaper.
    -Jason
