Coil Connectors
Discussion in 'Technical' started by Jaynik, Dec 7, 2004.
  1. Jaynik
    Jaynik Member
    Where can i get the proper connectors for the ignition coil cuz' I know these arent right. They keep falling off. And is that the corect guage of wire?
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Gauge looks good ... should be eyelet type connectors ...
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Dan is right, gauge looks good, just need the eyelet type ends. Available at Autozone or any auto parts store. Just cut off the old ends and crimp on the correct ones.
    Dan
  4. Jaynik
    Jaynik Member
    ah
    ah eyelet, thats what i needed to know. thanks
  5. bmcdaniel
    They're called ring terminals and if I remember right the threads on the coil's studs are 10-32. I use brass or stainless nuts and lockwashers.
  6. Mavaholic
    The coil you have in the picture is for a electronic Duraspark set up. There is a harness that plugs on the top of the coil and connects to both terminals. THey really wernt designed for individual connectors.
  7. Dan Starnes
    West Central IL
    ring terminals,, I used to know that. also,, good eye Dennis on that coil.
    Dan
  8. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    What Dennis said.Also the salvege yards should have plenty of OEM type connectors.Or switch coil to standard type.
