Coil question
Discussion in 'General Maverick/Comet' started by satchelmcqueen, May 4, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    I'm pretty sure they sent me the wrong coil. When I ordered the description said this coil would work with the petronix electronic points replacement. Does anyone know if this is the correct coil for this setup?
  2. William623
    Orlando
    1973 ford maverick grabber
    Flame-Thrower II is the correct coil for the the PerTronix system. There shouldn’t be an issue running the igniter I with the FTII. Normally I would just run it with a FTI though.
  3. satchelmcqueen
    north georgia
    I thought I ran this same set up before but couldnt remember. The worry I have is the instructions say not to use FT2 with the original petronix....yet doesnt describe what that is. Also it says .6 ohms for the coil...yet the distributor module calls for 1.5. I'm confused.
  4. William623
    Orlando
    If it says not to use the FTII then I would follow the instructions and return the coil for a FTI.
  5. Acornridgeman
    Wisconsin
    AC-191 is Ignitor 1 - uses FT1 coil / to run the FT2 coil you need the Ignitor 2 which is a 9AC-181 - if you have any doubts about what is compatible, Pertronix help line will get you right to a tech rep that can help with any questions.
  6. Krazy Comet
    The original Pertronix lacks any dwell control, meaning without a inline resistor(such as used with points) it will overheat some coils. My P-I overheated the original coil on my Cobra using the resistor.
    As far as the low resistance FT2, it would likely overheat the module.
  7. bmcdaniel
    The original Pertronix requires a minimum 1.5 ohm primary. You can add a series resistor if your coil resistance is too low but you're wasting energy in the resistor.
  8. satchelmcqueen
    north georgia
    Thanks all. I had to get the flamer thrower 1. Needed 1.5ohms
