coil spring Install
Discussion in 'Technical' started by AppMaverick, Aug 25, 2009.
  1. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Don't know whether I'm more embarrassed to say it took me six hours yesterday to get one spring back in or that I actually played with the spring like an idiot for six hours before it went in. I have a loaner internal compressor, the type with the four hooks. I did it with the upper arm installed but not bolted all the way down. Would it be easier to do it with the upper arm off and put it on after the spring is compressed rather than compressing the spring and trying to slip in onto the ring at the top? This should not take six hours, an internal spring compressor, external compressor, two people, two crow bars, a baby sledge, a roll of duct tape and alot of sweat is what I'm thinkin'....:hmmm:
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    They make a compressor thats way easier to do that. Im just not sure where to find one. I used one of a buddies once but have since moved, so i gots no clue.
  3. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    well crap. after posting all of that I gave the other side a try and the whole thing only took 20 minutes with the single compressor and two hands. I feel dumb. Did it the same way, don't know why it went in easy this time.... sorry guys. oh brother. This car might be the end of me lol.
  4. Mavman72
    It went faster the second time because you have experience with the process now :yup:
  5. 71gold
    I use this compressor...:thumbs2:
  6. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    That's the type that I wanted to use, but I get my money back from advanced auto when I return their loaner :yup:. As much of a pain that was I doubt I'll be taking them off again soon. (I say that now but watch them be off in a month again lol)
  7. 71gold
    this was a loaner from Auto Zone...:thumbs2:
  8. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    yahoo! :yahoo: That's awesome. Autozone is about 25 more minutes out of my way, but would have been way worth it.
  9. Mavman72
    ^I use this type also^ But...I dont use the fork.I have a 1/4" steel plate that I put "on top" of the shock tower.It wont move skip or jump around and positively locates the rod and hooks in the center of the hole in the tower.It works well.
  10. rthomas771
    The fork will not slip, skip or jump around either. I remover many of coil springs with the fork on top of the shock tower.
  11. Rando76
    Rando76 Member
    Claremore, OK
    I used one like this. I had to use a pipe in place of the washers to keep it from bottoming out. Otherwise it was perfect. I could remove the spring from the car while it was still compressed.
  12. Mavman72
    Been there...done that...Dont like it.Thats why I use the plate.Have you ever tried to get that stupid fork to stay put on the spring???...LOL...thats lots of fun!!!
  13. rthomas771
    Never had a problem with it...the grooves on the plate keep it from moving around
  14. yellow1970mav
    yellow1970mav Member
    cherry hill, nj
    1970 maverick, 2007 Yamaha FZ1,.
    fork style coil remover?
    this may be a stupid question but if you put the fork on top of the shock tower...how do you get the spring out when it's compressed? do you remove the spring perch and then losen the spring compressor? will that be enough room to pas the spring?
    thanks
  15. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    i just unbolt my upper control arm to give me more room. I cut the springs and changed the perches with the spring still in the tower. without the upper arm i don't think there's anything to get in ur way if you wanted to take it out tho. just swing the arm out of the way at the ball joint and uncompress the spring the same way you compressed it.
