There's a guy near to me selling "a set of new-in-box front coil springs, MOOG part #CS8354 that fit the following Ford models with V8 engines : 75-80 Granada & Monarch, 77 Comet & Maverick, 68-70 Falcon Wagon, 70 Ranchero." I assume that these will also fit my '73? Thanks for any input. John B
Rock Auto catalog- Here is what I came up with for the correct MOOG numbers for your 1973 - 1973 V8 car MOOG Part # 8304 Frt Susp; 2 Door; w/A/C $83.79$0.00$83.79 MOOG Part # 8318 Frt Susp; 4 Door; w/o A/C $91.79$0.00$91.79 MOOG Part # 8306 Frt Susp; 2 Door; w/o A/C $92.89$0.00$92.89 1973 I-6 200 CID MOOG Part # 8318 Frt Susp; 2 Door; w/o A/C $91.79$0.00$91.79 MOOG Part # 8306 Frt Susp; 4 Door Frt Susp; 2 Door; w/A/C $92.89$0.00$92.89
When I looked up that 8354 spring - it is listed for a: Granada with an I-6 200 CID non A/C MOOG Part # 8354 Frt Susp; 200 w/o A/C* Non-stock item--shipping delayed up to 2 business days $71.79 $0.00 $71.79 I would think it would bolt right in - but it sounds like a pretty light duty spring.
According to my chart...8354's fit a '77 302 V8 w/A/C...1587# load rate...262# spring rate. 8306 have a 1519# load rate and 262# spring rate. http://1bad6t.com/Maverick/repair/coilsprings.html
Coil spring chart can't hold a candle to the leaf spring chart http://1bad6t.com/Maverick/repair/leafspring.html
I've got a problem with those spring rates don't they look bass-ackwards? I thought the fronts were around 400-500 and the rears were 150-200... Russ
