Coil spring removal require spring compress?
Discussion in 'Technical' started by Wantamav, Dec 26, 2006.
  1. Wantamav
    Wantamav Located in Macomb Mi.
    Michigan
    '71 2 door
    Do I need to use a sping compressor to remove the coils from the front of the Mav? Installing the Granada spindle stuff and I've realized that I'd better check (or replace) all of the wear items while I'm in this deep. Advise? :huh:
  2. Wantamav
    Michigan
    '71 2 door
    I should have been more specific, I plan to replace the shocks and would like to inspect the upper spring seats as well. Thanks, Todd
  3. scrapper60
    scrapper60 MCCI Member
    Alabama
    Yes, and remove the A arm to check the A arm bushings and shaft for wear along with the other items you're going to check/replace.
  4. 71gold
    ...install...zert fittings...in a arm shaft :yup:
    ...frank...:bouncy:
