Column Shift Indicator Bulb
Discussion in 'Technical' started by jonhackworth, Nov 11, 2011.
  1. jonhackworth
    jonhackworth Member
    San Diego Area
    1974 Maverick 2-Door
    okay how the heck do you replace this bulb? Really, you don't have to pull the column right? :hmmm:
    I took off the plastic cover and clear P R N D 1 2 piece and can clearly see the bulb...but see no way to get it out.
    A little help would be most appreciated. May kid has to turn on the dome light to see what gear she is in.
    Thanks!
  2. rthomas771
    Remove horn switch, steering wheel. Remove the turn signal lever and the screws on the turn signal switch and swing the TS switch out of the way. Remove lamp from the flange casting.
  3. Craig Selvey
    Yep....got to pull the steering wheel and turn signal switch.
  4. G3blues
    G3blues Member
    MI
    1972 maverick sprint 302
    Does anyone know of a brighter bulb? I replaced mine when I replaced the turn signal switch and it is still really dim. I know you can replace the ones in the dash but what about this one?
