Column Shifter
Discussion in 'General Maverick/Comet' started by fullcm, Sep 18, 2022.
Tags:
  1. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Lately I have noticed a lot of slop in my column shifter handle. The shift indicator stays put so I think the play is all in the handle. I tried to attach a video but cannot, below are a couple of photos at the top and bottom of the handle slop while in drive, it is about 2 inches total. Any ideas what could be the cause and how to fix it?
  2. Krazy Comet
    Worn shift collar, common problem.
  3. fullcm
    fullcm Doug
    Michigan
    74 maverick
    ok, I saw those collars in the AutoKrafters catalog. Does it require removing the steering wheel?
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Yes, to replace the collar the wheel must be removed. You may want to examine the linkage before you do or purchase anything. IIRC there is a nylon grommet that the linkage connects to near the end of the column under the hood. If that grommet was damaged it could give you some slop in the linkage.
    71gold likes this.
  5. fullcm
    fullcm Doug
    Michigan
    74 maverick
    ok, I will be sure to check that linkage under the hood first, might save me a lot of work. Thank you.
  6. jasonwthompson
    Carrollton TX
    You should be able to tell by looking at the collar and lever. If the slop is all in the lever and the collar does not move, it is probably as Tom stated, new collar needed. If the slop is from the collar moving and not the lever, it could be linkage.
  7. Craig Selvey
    Could be as simple as the drift pin has moved. The drift pin holds the chrome rod to the steering column collar. Very common problem on an old Ford. The one on my 1976 Maverick does this. Move the pin back and all is good.
    dyent and Krazy Comet like this.
  8. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Hey Craig, I think you are spot on here! It looks like that pin has slipped down and it is not even engaged with the top hole in the shift collar.
  9. fullcm
    fullcm Doug
    Michigan
    74 maverick
    All set now. I just tapped that pin back up into place with a small hammer and no more play in the shifter! Thanks Craig.
    Craig Selvey likes this.
  10. fullcm
    fullcm Doug
    Michigan
    74 maverick
  11. fullcm
    fullcm Doug
    Michigan
    74 maverick
    Thanks Jason that drawing is nice to have on hand. As it turns out, Craigs suggestion to check that shift lever drift pin was my only problem. I just tapped it back up into position and I'm all set now.
    jasonwthompson likes this.
  12. Krazy Comet
    Good call, I tend to forget the obvious is often overlooked.
  13. Craig Selvey
    Keep an eye on it.....it will probably slip again. Mine does all the time.
  14. dyent
    dyent Member
    vancouver bc
    If roll pin is worn, can always get a new one at any hardware store or a #8 bolt will fit fine too.........
    David
