comet gt scoop location
Discussion in 'Technical' started by inline6, May 24, 2005.
  1. inline6
    inline6 Member
    for anyone who has a comet gt scoop on a plain maverick hood..can anyone tell me how far you mounted your scoop(the distance between the back edge of the hood,to the back of the scoop)?i like the scoop on mavaholics,and dmhines car.i just don't want to mount it too far forward.thanks for any and all help...chuck.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Are you using a repop or original?
    The repop has studs at the very back of the scoop so unless you want to drill access holes in the rear underhood support area to get install the nuts on the studs you have to mount it further forward than the factory scoop. The factory scoop does not have studs in the back so it can overlap the support at the rear underside of the hood.
    I mounted my repop as far back as I could without having to drill access holes in the support. The factory scoop sits maybe 1 inch or so from the back of the hood. My repop sits about 4 inches or so from the back of the hood ...
    Make sense? Dan
  3. inline6
    inline6 Member
    thanks dan for the input.i am using an orig.gt scoop.just wasn't sure where to mount it,and didn't want it too far forward on the hood.
    chuck.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I can measure mine, off the top of my head I would say it is about 1 - 1 1/4 inches from the edge of the hood. I have an original GT scoop on mine.
  5. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    I put mine at 2" at the center of the hood near the cowl.
  6. Mavaholic
    I dont have a GT scoop on my Sprint.
  7. inline6
    inline6 Member
    my bad,maybe i was thinking of an older pic that you posted.
  8. dmhines
    Cumming, GA
    Here is a picture ... Factory location on top ... my repop on the bottom ...
  9. dmhines
    Cumming, GA
    Dennis has a scoop ... just not a Comet GT scoop ...
  10. inline6
    inline6 Member
    thanks maverick1970,and russ.
    dan,thank you for the pics...just what i was looking for.
