Comet Side Trim Removal
Discussion in 'Cosmetic' started by Rad_Dad, Apr 8, 2019.
  1. Rad_Dad
    Rad_Dad Member
    NorCal
    1973 Mercury Comet
    Any idea how many holes beneath the chrome side trim on 73+? It's a shame to hide that nice body line.
    Cheers.
  2. dyent
    dyent Member
    vancouver bc
    If you are talking about the LDO trim, chrome w/color pad insert, only has 2 holes on either end the rest has raised
    "pins" approx. 6 of them. So unfortunately, if you want to see that nice body line, you will have to grind off the "pins" and fill in the 2 holes, then repaint..........that's just on the doors, the rear quarter and front fenders all have holes.
    David
    Rad_Dad likes this.
  3. Rad_Dad
    Rad_Dad Member
    NorCal
    1973 Mercury Comet
    Thanks. I knew a repaint would be required just wasn't sure about body repair.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Is that for all the trim pieces? On the standard rub strips for the non LDO cars there are a lot more holes that that, The door only has two but the quarters and the front fenders are mostly holes.
  5. Buck62
    Buck62 Member
    Chicago IL
    1974 Mercury Comet (Base)
    We eliminated the side trim on our '74 Comet. I can't remember how many holes were left after removing the clips, but we filled them with fiberglass.
    Here's the result...
  6. Retiredguy67
    Retiredguy67 Member
    NC
    1971 mercury comet
    Info needed, retired guy here with my 71comet. I got side molding off fairly easy but now i got 20 plus holes to tig weld or glass over. The trim around the windows needs removing. Any good suggestions? Molding looks really good on entire car. 69,000 miles. All original. 200-6cyl. Runs. I just need a carb and new fuel tank.
  7. Retiredguy67
    Retiredguy67 Member
    NC
    1971 mercury comet
    Good morning/ just wondering if there is anyone out there!!! I see older comments but nothing new. Does this site still have viewers that are into comets and mavericks? O well , :(
    Thks guys
  8. rachjake
    rachjake Member Supporting Member
    Pace, FL
    1975 Maverick
    We are still out here. I have been collecting parts for my 1975 Maverick for a little over a year now..
    I hope to get serious this spring - - - -
  9. Retiredguy67
    Retiredguy67 Member
    NC
    1971 mercury comet
    Good morning ☀️, iam looking for a 1 bbl carb . Iam also trying to find everything to change hubs to 5 lug. Comets are getting harder to find. They out but you sure have to inspect all shelters and wood lines.
  10. Powerband
    Powerband Member
    NY's \H/
    "... you sure have to inspect all shelters and wood lines."
    HAH
    - Isn't that the truth !
    resurrecting or adding to a 6yr old old thread may not generate much interest.
    probly' better off starting a new thread / post with specific question/s and may get helpful response.
    carbs like the Carter YFA in pic - rebuild kits, used carbs, knockoffs are widely available for the inline Ford small block six.
    '71 4 lug used the short lived 4 Lug 8 " that can use same internals like Posi' as venerable 9" Ford rear but uses unique axle housing for different hub size bearings - SO - 5 lug - 8" axles don't fit in the 4 Lug 8" axle housing. Re-drilling flange may be 5 lug option ?
    Swapping to later spindles and hubs etc is typical for 5 lug front wheel swap .
    for performance and Drivability upgrades to Ford Six's, check out another friendly related forum:
    https://fordsix.com/
    have fun
    '74 MavComet W/ Ford 250 Six, Vortech VII , T5, 5 Lug 8" rear axle, '76 Comet front Spindles W/ Disc Brakes, a few other things...
    '61 Comet with Maverick 250 TriPower Six, T5, 8" Maverick 4 Lug 3.80 Posi rear axle, 71 Maverick 4 Lug Spindles with Disc adapters, Traction devices, Frame Connectors, RollBar, Track Legal...
    [​IMG] .
    Have (4Lug) fun
