Comet won't freakin' start again!
Discussion in 'Technical' started by Comet4me, Nov 5, 2012.
  1. Comet4me
    Comet4me Member
    1975 Comet
    Need help, broke down in driveway.
    Getting fuel, but turn engine over and get nothing. Turn off key, engine rotation kicks backwards for a 1/4 rotation. Checked spark by holding a wired plug 1/4" away from good ground. Cranked engine for 5 seconds, no spark. But when I turn the key off, i get a strong spark. Did the same spark test with distributor wire from coil. Turn key on...spark, turn key off...spark. New cap and rotor was recently installed and it has been run since then. Any ideas?
    Inline 250
  2. mercgt73
    check the points.
  3. Comet4me
    Comet4me Member
    1975 Comet
    I should mention, we had this problem once before when we replaced the voltage regulator and battery. It wouldn't start for an hour and then it finally decided to start for no reason. Then we've started and driven it a few times since then with no problem. Then tonight, all I did was replace a thermostat and then bam, dead again. I just drove it last night too.
  4. Comet4me
    Comet4me Member
    1975 Comet
    Do bad points work intermittently?
  5. mercgt73
    They sure can. That is, ofcourse, if you have points. I'm not sure when breakerless started...
  6. Comet4me
    Comet4me Member
    1975 Comet
    Ok, now to look up how to do that. Yes they're points.
  7. Comet4me
    Comet4me Member
    1975 Comet
    Maybe I'm wrong. I don't know much about this. Here is a pic.
  8. Comet4me
    Comet4me Member
    1975 Comet
    Ok so it seems like its a Duraspark. Now what? Do I still have a distributor issue?
  9. 71gold
    not points...
  10. Comet4me
    Comet4me Member
    1975 Comet
    So back to original post...any more ideas?
  11. Mavman72
    Ignition switch at base of column is bad...No voltage to coil in crank position, only in run position...At least thats what it seems like to me...:huh:
  12. darren
    Gees he beat me again. Lol
  13. Comet4me
    Comet4me Member
    1975 Comet
    Is there a way to bypass the ignition switch to start the car?
  14. Comet4me
    Comet4me Member
    1975 Comet
    I can't find that part anywhere, only the ignition module, and key barrel assembly. Nothing for the base of the column.
  15. Comet4me
    Comet4me Member
    1975 Comet
