Coming soon cowl repair
Discussion in 'Technical' started by jasonwthompson, Jun 20, 2013.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I am planning a cowl leak repair in the very near future. I was contemplating replacing both the heater and evaporator cores while I have it torn down. For anyone who has done this, what else would you recommend replacing while it is apart and are there any gotcha's I should be aware of? It is a 75 Maverick with factory AC.
    Thanks
  2. mojo
    If u plan on using the AC; I wud also replace the expansion valve and drier. U can also have the reciever/drier repaired/rebuilt. U will not likely be able to replace the evaporator - I wud take it to a radiator shop for testing and if necessary, repaired.
    If ur trying to keep the car stock, u can have the condenser repaired and get rebuilt compressor.
    I did the complete HVAC upgrade w/ all new stuff frm Classic Auto Air in Flordia.
