Im ready to put a new exhaust system on my 302 1970 Maverick and this is the set up i have picked out so far and would appreciate any comments or suggestions on what you think and if it would be good backpressure and performance/sound or if it will even fit, since im not the smartest when it comes to exhaust. Thanks for any help.... Hedman Hedders 88300 http://store.summitracing.com/partdetail.asp?autofilter=1&part=HED-88300&N=700+115&autoview=sku Dynomax Connector/Reducer 3in - 2.5 in http://store.summitracing.com/partd...part=WLK-41973&N=700+-146799+115&autoview=sku Pypes X Pipe 2.5 in http://store.summitracing.com/partd...VA10&N=700+401344+4294908331+115&autoview=sku Purple Hornies 2 1/4 - 2 1/4 mufflers http://store.summitracing.com/partdetail.asp?autofilter=1&part=BIG-50225FLT&N=700+115&autoview=sku Ending with some type of 2 1/4 straight pipe or turn down pipe or fitting a 2 1/4 - 2 1/2 connector to the Purple Hornies and ending with a 2 1/2 straight pipe or turn down pipe http://store.summitracing.com/partd...art=SUM-640025&N=700+-218808+115&autoview=sku
you also ned the drop bracket. see the side note on the header section They are no cbig deal to install, it's just that you need them. If you have a column shift, you'll need to change to a floor shifter. HED-20120 HOK-10961HKR WLK-88303
i used the bracket and still could not turn the wheel a happy amount. if you go with headers but want to keep power steering, sell the headmans and buy the hookers that everyone else has...
Ive got those headmans with a 2.5 h pipe into flowtech terminators and 2.5 tailpipes.Had to use a p/s slave cyl drop bracket also.
