conecting subframes
Discussion in 'Parts Interchange' started by cometguy1971, May 16, 2014.
  1. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    hello im a new member, i have a 71 comet with a 302,and i need to connect subframes ,who has the best kit?
  2. Dave B
    Try searching it, you'll find your choices are pretty limited.
  3. 71gold
    :Welcome:...:Handshake
    they are something you can make or have made. mine were made at a muffler shop...:thumbs2:
  4. Craig Selvey
    Welcome to the board from your neighbor to the west.
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Global West has a set that will weld right in,no mods & good quality.A friend of mine just welded a set into a 65 Falcon,I`m pretty sure they will fit our cars also.
  6. mav1970
    I have some distant relatives living in Painesville Ohio
  7. skin
    skin Registered User
    Northeast Ohio
    '73 357ci Grabber
    Welcome
    From Mentor!
  8. bmcdaniel
    bmcdaniel Senile Member
    :Welcome: I used Competition Engineering subframe connectors for an early Mustang.
  9. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    thanks everyone!would really like to find a good welder in my area.....to the mentor guy i think i seen u roll threw anabelles last summer
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Alston Race Cars#064-102419
    Bolt On Subframe Connector
    1970-77 Maverick
    Powder Coated Black
  11. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    is round or square frame connectors better?......also...so how do u add images?
  12. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
  13. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Technically round chromoly would be best/stronger all around then any square tubing
    but if you know direction of bending force then square would be better
  14. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    thanx hottrod1991...i havenent seen any round kits out there..so it might have to be square..unless i find a good welding guy.also does anyone know what other car parts swap over to my 71 ?i have a friend that has a 68 thunderbird wit a ford 9 "n" stamped rear end wit 31 splines,was wondering if that would fit?,i have 8.8 right now
  15. car-nut
    car-nut Glenn
    conn.
    I have a pair of square tube sub connectors I am not going to use. If you are interested send me a pm and we can talk.
