Consolette
Discussion in 'General Maverick/Comet' started by 73curtis, Nov 6, 2015.
  1. 73curtis
    73curtis Member
    ohio
    does anyone know how the Consolette was mounted in the car , (bolted down or did it just sit in the middle? And what years were they available?
  2. 71Mavrk
    71Mavrk Member
    Nevada
  3. 73curtis
    73curtis Member
    ohio
  4. 73curtis
    73curtis Member
    ohio
    Does anyone know of any other clock that will fit and look good other than the original?
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Curtis,
    I suspect that cars with the later dash which included a glove compartment would not have needed a Consolette.
    Micah
  6. 73curtis
    73curtis Member
    ohio
    That's true I guess I should've thought of that ,that makes sense
  7. Paul Masson
    1971 Grabber
    The clocks never seemed to work right. Kboldin wrote a thread on how to basically rebuild/tune-up the consolette clock.
    http://mmb.maverick.to/threads/consolette-clock-repair.97582/
    Not all consoettes came with clocks. There was a block-off plate that was used to fill the hole if there was no clock. The plate was black plastic and just had the steer-head emblem on it.
  8. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    The consolette was offered in 1970-1973 Mavericks and 1971-1973 Comets. As Paul stated above, Mavericks could be ordered with or without the clock, all Comets came standard with the clock if the consolette was ordered. Attached is a page from the 1972 Mercury Accessories dealer booklet.
    The same OEM clock was also used in the consolettes that were offered for the 71-73 Ford Pinto, the Pinto consolette is different from the Maverick consolette, but the clock was the same. Also, due to the shape of the trans tunnel, the consolette for the 1970 Maverick was different than the consolette offered for the 71-73 Maverick.
    Paul Masson likes this.
  9. 73curtis
    73curtis Member
    ohio
    Does anyone know what the difference was ? Was it all wider or just the bottom a little wider I can find a 1970 but not a 1972 I wonder if I could ale it work ?
  10. 73curtis
    73curtis Member
    ohio
    I found a parts break down and it says 70 -72 and then 73-77 but they both have the same part number
