helo!!!everybody!i need helph with my c4 transs ,wath converter i use in my car,with 4:11,ratio,11:5:1 compressiosn,and X303cams,thanks!
something big i would guess... the cam should have came with like 2000-6000 rpm range on the box and i believe you will be better off with the same for the converter
A lot depends on what you want to use it for. Your best bet is probably to call one of the manufacturers and see what they reccommend. You might even try a couple of different companies. They'll probably ask you what you're wanting to do with your car and the weight, and some other stuff.
Yeah they will want a full run down of the cars stats from were the gas goes in to were the exhaust exits, you will fill like your being examined by a doctor. Most of them will have sheet for you to fill out (been there done that) be prepared to spend at a minimum $500.00
