Converting: 3 on Tree to C4 floor shift.
Discussion in 'Technical' started by Maverick_Matt72, Mar 3, 2007.
  1. Maverick_Matt72
    Maverick_Matt72 Member
    Deep In The Heart Of, Texas
    '69.5 Maverick
    When converting from 3-on-the-tree to a C-4 on the floor, what crap do I need to rip outta the steering column??... I'm sure there's lotsa extra junk in there... or do I just disconnect the linkages to the tranny and the shift knob???
    Also, is there any trick to removing the whole clutch pedal and clutch mas/cyl and all that jazz?
  2. Mavaholic
    You really dont need to remove anything from the column but you do need to lock it in reverse so you can remove the key. The easiest way is to make a small bracket and bolt the shift arm to the firewall in the correct position. You will have to move the reverse lite switch and use the one on the shifter.
  3. chandler
    chandler Member
    Warrenton Mo
    Maverick
    Drop me a PM Maverick Matt72
