Cooling fans - dimensions?
Discussion in 'Technical' started by RASelkirk, Mar 12, 2014.
  1. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Don't remember seeing any fan articles with dimensions. I'll soon be needing an electric fan for my Rambler project, the radiator is 24"w x 19"h overall. I'm pretty sure the Taurus fan will be ideal with the possible exception of depth. Not real sure how much room I'll have to play with. Anyone know if there's a chart listing various factory fan dims with their depths?
  2. Dave B
  3. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
  4. Dave B
    I have a Taurus fan I can measure for you.
  5. 71gold
    we found that the...Taurus fans...have different depths...depends on how the motor is mounted. I found this out when I went to replace mine with a new one. the plugs are different also (3) that I know of. Jamie Miles mounted his motor to the front side of the shroud and gained some more room.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    The links Dave provided got me looking at the Contour/Mystique dual fans, that will definitely clear my water pump pulley. Not sure how much air they'll move though. If I can find an LS2 pump with the short pulley, any Taurus fan should clear, but for now I'm stuck with the early C5 pump with it's long style pulley. I know ya'll don't really want to be hearing about this LS stuff so I'll shut up now...
