Correct Parking Brake Operation - 73 Comet
Discussion in 'General Maverick/Comet' started by Big Dadio 1, May 11, 2006.
  1. Big Dadio 1
    Big Dadio 1 New Member
    Manitoba
    1973 Comet
    Hi;
    Can someone explain the correct operation of the parking brake on my 73 Comet? I took my car in to obtain a safety certificate for registration and the mechanic indicated on his report that the parking brake does not light the red brake light indicator on the dash when hand lever is pulled .......from what I can determine from looking at the under dash parking brake mechanism there is no provision to light the indicator light....can some one clarify this for me?
    Thanks from A Comet newbie....
    Big Dadio 1
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Tell the idiot it is not supposed to!
  3. grbmaverickmo
    Aquashicola, PA
    Light doesn`t go on with the P brake.
  4. Mavaholic
    That light is wired to the distrubution block. If you loose pressure in either the front or back, a little piston moves and turns the light on.
  5. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    My 73 Comet dos'nt have a light for the P-brake. Sounds like He just dos'nt know that thers not suposed to be one.
  6. mercgt73
    Poor mechanic... maybe never even seen a Comet in his life... go educate him politely. Then do a burnout when you leave AFTER you get your paperwork.
  7. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    As far as that Mechanic goes " The light is on, but there's nobody home"
