I still can't get three intake valves to close. I'm not sure if they're stuck or bent, but regardless if I decide to keep this 75 mav I'll need a valve job. Any idea how much one would cost? Cheaper to take a chance on heads form a place like pullapart? This is a 4 door LDO with an outstanding body and I'm not sure if it's worth it or if I should sell it or part it out. Thanks Bob
I'll try to get them up tonight. The only issue with the body is some small holes where the vinyl top seam was, but I was planning on welding a piece in and replacing the top.
Pull the head and look for piston/cyl bore damage.If you dont find any then its definitely worth another head or a valve job.If the valves got cozy with the pistons...Well it may be V-8 swap time.
