Couple ??
Discussion in 'Technical' started by GrabberGT, Mar 27, 2004.
  1. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I recently purchased a new carb (Holley 670) and was wondering what was involed in putting it on. It does not really seem that hard but I dont want to leave anything out.
    Did the mav come with a radiator overflow resevior. I need one and dont want to spend 50.00 on an aftermarket one.
  2. riporter
    riporter Member
    Charleston S.C.
    My cars were built prior to 1973 and none of them were equipped with overflow tanks...just discharged by hose to the ground.
    Not knowing what carb your swapping from its hard to say what probs you may have.
    The only Holley I ever put on I was pulling an Autolite off and it was no prob at all, some slight tuning on the air to fuel ratio and it worked perfectly.
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    what carb is on you`r mav now is it the stock one if so you`ll need to get a 4V intake
  4. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    It currently has an older Holley 600 4 barrel.
  5. elliot
    elliot Member
    Boubon MO
    In that case it should just bolt right on but you might wan`t to look both of them over before you dig into it
  6. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    are there any torque specs that I need to worry about?
  7. riporter
    riporter Member
    Charleston S.C.
    None that I'm aware of...just snug em up good. I run a light bead of RTV caulk around both sides of the gasket also.
  8. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    thought of a problem. The new carb has electric choke. How do I wire that in. I have a Mallory 6 ignition box and an MSD dist. (I wish this thing would have come with instructions but thats the price you pay for saving money on used items)
  9. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    The choke wire runs off the back of the alternator, if your original was electric than the wire is already there. If not, you can run off any source of ignition positive. Do not use battery positive, just ignition positive.
    The only other difference might be your fuel intake lines. If your 650 is a double pumper, you may have dual fuel inlets, where all the 600cfm carbs have single inlets, for the most part. Check before you start, and if you have dual inlets, you will need to buy the lines. Buy a name brand, the Summit house brand stuff is cheap and leaks more often than not.
    You don't need rtv to seal the carb to intake. A fresh gasket will be fine and require no clean up down the road. You shouldn't need rtv for anything vacuum related.
  10. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Summit and Jegs both have radiator overflow jugs for about $15.
  11. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    OK I ran into a problem. Apparently one of the carb mounting studs had been striped out of the intake before and not fixed. What should I do, helicoil or by a new intake. The old intake is (I think) a single plane holley street dominator. It has one big intake hole instead of a split intake hole. With this being a street car, I figure a dual plane should put the power where I need it. I was thinking of going with the Edelbrock Air Gap but am open to suggestions. Engine specs are as follows:
    306 cid
    Holley 670 street avenger
    Intake _to be determined
    351 windsor heads - ported (upgrading to AFR next year)
    Headman 1 5/8 headers
    TRW forged pistons (compression ~9.5:1)
    Comp Cams 270h
    C4 2500 stall (changing to T5 next year)
    3.00 open rear (3.55 or 3.80 locker next year)
    Thanks
  12. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I will be installing my new intake this weekend. There is a heat difuser plate between the carb and intake. Is it really needed?
    I also removed my valve covers to do some customizing. Someone mentioned to me that I might want o check my valve lashing. Any idea on what it should be set at and how to check it?
    Thanks for the help.
  13. Max Power
    St. Paul, MN
    Your cam is hydraulic. Unless you are hearing any funny noises, I wouldn't worry about valve lash. That's a concern for mechanical cams mostly, not hydraulic.
    A Performer RPM would be a good manifold for that combo.
  14. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    the intake is actually the Edelbrock air gap. I hope I picked a good one. Anyway, thanks for the info.
  15. Max Power
    St. Paul, MN
