cragar wheels
Discussion in 'Technical' started by elliot, Dec 2, 2005.
  1. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Hello every one , I need to know if 15x8 cragar wheels will fit in the rear of my maverick with P215/70R15 tires. Once them are worn out how wide of a tire can put on there without rubbing ?
  2. MikeG747
    MikeG747 Member
    Arkansas
    Elliot look at the Thread down the page from this titled "4 1/4" BS". It has a lot of good examples of different size wheels & tires that other members have used. It's a wealth of information on the subject. Good luck.
    Mike:)
  3. stmanser
    Davenport, Iowa
    yes a 15x8 will fit... BUT...P215/70R15 tires are WAY to small...
    15x7 will fit those tires better
    15x8 would best fit a 235 60 15 to 255 60 15 tire...
    i am going to get 15x8 rims and 245 60 15 tires... if i can find them cheap enough.. its an odd ball tire.. so they might be pricey..
  4. bmcdaniel
    I just priced the BFG Radial T/As a few weeks ago. 245 60 15 and 255 60 15 were both the same price. Local place wants $194 a pair including mounting, balancing, stems. I'm going with the 255s.
  5. tim keck
    sharps chapel,Tn
    Not on a 4dr Elliot.I had some 15x7 dodge cop wheels on my 75 4dr and that was all it wanted.If you look at them,the quarters on the 4drs don't "swell out" like the 2drs do.I had 255/55's on mine and had to use 1/4" spacers to keep them from rubbing the springs,and only had about 2 fingers at best(yea,I know real scientific measurements) between the outter rim and wheelwell lip.Your tire size would work well on a 7" rim,but the 8's are too wide for the 4dr(at least mine).
  6. elliot
    elliot Member
    Boubon MO
    The 15X8 wheels will work , they have to since I already sent off for them .
  7. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Well I just purchase a full set of Cragar Soft 8 wheels with a 4 inch backspacing, Can't I use a 295/50/R15 tire in the rear?
