Cruise control option in '72?
Discussion in 'General Maverick/Comet' started by bmcdaniel, May 26, 2011.
  1. bmcdaniel
    Was cruise control an option in '72? Or any year?
  2. injectedmav
    injectedmav Member
    Georgia
    To my knowledge the only cruise available was dealer installed in the later years, 76-77
  3. Craig Selvey
    I have never seen factory cruise control on any Maverick/Comet.
  4. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    The only ones I've ever seen in Comets and Mavericks are the aftermarket ones.
    I can't stand the looks of the aftermarket cruise controll units just sitting on the turn signal stalk, so the only cruise controll I have on my Comet is my right foot! :thumbs2:
    But then again, I have a Cadillac Deville 60 Series and a F-150 for road trips so I don't need one in the Comet.
    -Scott H.
  5. bmcdaniel
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I cant get ebay pic on my phone,,
    From what I see it is a sensor they had to knock timing out and allow engine to burn more of the gas. it sensed this to 30 mph, not positive on excact mph.
    Been a while but it was discussed here.
    I can get more info if you want it Barry
  7. injectedmav
    injectedmav Member
    Georgia
  8. Craig Selvey
    That is correct. I parted out a 1972 California car and it had this set-up on it.
  9. bmcdaniel
    I was wondering if it is a magnetic sensor and if it could be adapted for use with a cruise control. I have an old, never installed, still in the box, cruise control from the 70's that uses magnets attached to the drive shaft to sense speed. I was thinking if this cable has a magnetic sensor I might just be able to that as a speed sensor for a cleaner installation.
  10. rthomas771
  11. bmcdaniel
  12. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    They didn't offer the option for Mavericks because Maverick Guys are too cheap! :D
  13. injectedmav
    injectedmav Member
    Georgia
    Theoretically, it should work. It's just an AC generator. It really depends on the amplitude and frequency required to operate your control unit but most systems just sense the frequency when you push the set button and try to maintain that frequency by modulating the throttle control. I'd say try it. It would be a lot cleaner install than the driveshaft route. The speedo cable on mine I believe is different but it may plug in regardless. (y)
  14. Craig Selvey
    Barry....if you are interested I still have all the parts.
  15. bmcdaniel
    Hey, I resemble that remark!
