Crumbling Instrument Cluster
Discussion in 'General Maverick/Comet' started by fastback86, May 28, 2014.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Has anyone thought about trying to make a mold from a good instrument cluster housing and casting some new ones out of fiberglass or something? I believe you can buy kits to do this from art supply stores.
  2. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    I'm sure it's been thought about, it's just not very cost effective or easy. Compared to something like a hood, the cluster housing is a small part with tight corners, and that makes it difficult to make out of a material like fiberglass (or carbon fiber).
  3. fastback86
    FL
    I was thinking of a pour in type casting.
  4. musicluvr
    musicluvr New Member
    North Carolina
    1976 Ford Maverick
    if you find a successful way to do it, that would be something I would be interested in, my cluster crumbled and I found a replacement but even the plastic in that is starting to dry rot, so good luck! I have even thought about if someone could fabricate it out of a thin metal and then coat it in a material that is not a conductor so there is no interference with the wiring. that might be something to look into.
  5. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Shouldn't be too difficult. The mold would need to be a 2 part silicone mold, once the mold is made you could mix an epoxy catalyst and add any color dye you want (such as white) pour it in the mold and remove cast from mold after product has cured.
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    imo, silicon mold casting would probably be the best way, or a harder mold
  7. fastback86
    FL
    Anyone have experience using molds? I was wondering through a Hobby Lobby while the tire store was mounting tires for me and I came across their mold making stuff and it got me thinking. I'm sure there are a lot of us here that would like a new cluster housing and I may need a custom one.
  8. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    I have an NOS white cluster back. When time permits I'll see about an attempt at it.
  9. junrai
    junrai Member
    rancho cordova ca
    why go through all of the trouble when you can just switch to the 72 blue/green ones and all you have to do is change the plug from the earlier car. assuming youre having trouble with the white cluster
  10. rthomas771
    The early 70-73 cluster harness doesn't work with a 74-75 harness...different wire count and wire colors. Also one of the circuit tracks crosses over the cluster hole. They say a 76-77 circuit board will work on a 74-75 cluster back.
  11. jtown77
    jtown77 Member
    Arizona
    71 Comet
    I can see if my son can put it into AutoCAD. Then you can just have one printed at Shapeways.com. Just not sure of the price.:huh:
