**Curious**
Discussion in 'New Members Forum' started by TrinasMaverick, Jan 8, 2005.
  1. TrinasMaverick
    TrinasMaverick 1975 4- door maverick
    United states
    "75" Maverick, 4 doors
    :huh: I dont know very much about cars but i was wondering what could i do to my car to help it start up right away...normaly you have to pump it for a little bit then it will start...is there anything that will help?:hmmm:
    -TRINA
  2. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    as far as I know, that's just a trait of carburated engines, maybe you could change the choke on the carb, but not sure how much that whould help pumping the gas
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    A good tune-up works wonders...
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    These cars are not fuel injected like modern cars. It is very normal to have to pump it.
    Dan
  5. TrinasMaverick
    United states
    i just thought that you could do something...for less pumping. A guy i work with said i might need a new carb. kit??:confused: i dont know how this would help.?
  6. Mavaholic
    Probably not, especially if the car runs fine once its started. As suggested, get a good tune up and have the choke set properly. I believe 75 was the first year for electronic ignition so you should have that already. If not, I'd convert it.
  7. TrinasMaverick
    United states
    thanx for the help(y). yes it does have electronic ignititon. it runs great once its started and it has a brand new tune up!!
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    really just the nature of the beast.....someone with another maverick might get in it and if he/she pumps the gas it will flood.:huh: ...some do, some don't:hmmm: . As long as it is driving good I would not have a great concern about it.
    Welcome.
