Cutting coil springs Help
Discussion in 'Technical' started by Acedmav75, Jan 1, 2010.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Im redoing the front suspension on my mav and i wanted to cut about an inch on the coil springs. I have a i6 right now but plan on dropping a 302 in it. Should i wait till i drop the 302 in before i cut them? Will it sink lower cause of the weight of the 302 or will the shocks counter act that? Thanks for the help guys!
  2. Joe Dirt
    mine has 250 6 cyl a/c springs under it
    I cut about 1-1/4 coil with the 302 f/i in it and a 2" rear block
    before and after
  3. scooper77515
    Wait, the extra weight of the 302 may get you where you want to sit. There is no telling how much spring is left in your springs.
  4. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Thanks a ton joe this is exactly what i needed! oh and Happy New Year! (y)
  5. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    i was planning on only cutting an inch this way itll give me some leeway to do some other things. thanks for the tip though i appreciate it!
  6. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    hey joe what 302 do you have in your mav and how in the world do you get such high MPG! :hmmm::hmmm:
  7. Joe Dirt
    its fuel injected and has a overdrive trans I drive it like a old lady:yup:
  8. rthomas771
    The 6cyl weighs about 385 lbs, the 250 a little bit more, the V8 weighs around 460 lbs plus the V8's weight will not be sitting directly on the front suspension like the 6 cyl does. The weight will be shifted slightly more to the rear of the car taking the weight with it. If you plan on aftermarket exhaust and intake this extra 75 lbs will almost disappear.
    The V8 cars with out AC got the same spring as the 6 cyl car with AC so theres not as much difference than you think. What makes the difference is how worn out the spring is
  9. blugene
    If you cam wait that would be best. And, shocks don't counter act anything as far as load. They absorb shock.
  10. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    What he said. Put the motor in and drive it around and let it settle down. Then start cutting if necessary.
  11. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Cut it short. You can always cut it again later ,but if you cut it too much your done.
