Cutting sheetmetal; what do you use?
Discussion in 'Technical' started by John B, Aug 4, 2006.
  1. John B
    John B Member
    Ontario, Canada
    '73 Mav
    I don't have much experience with cutting sheetmetal. To date I've just used some old snips that my dad left me, with unsatisfactory results. What kind of tools are you using for this job? Thanks. John B
  2. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Band saws work pretty well, but a nice big one is expensive and hard to come by. A pneumatic nibbler works pretty well. You can use a standard sabre saw, but it needs a very fine blade and lots of support or it just bounces up and down without cutting anything. Plasma cutters are nice to have around if you dont' mind messy edges and lots of slag.
  3. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I use a Jig Saw/Cut-off Wheel/Sawz-All for thin stuff.......for thick stuff, I try to find a plasma cutter to borrow!!
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Can't beat an air powered cut off wheel, leaves a clean smooth edge. Just a little slow, can't push it.
  5. luckyirishpride
    luckyirishpride "Youngest Comet Owner"16!
    Southern California
    2x 1971 Mercury Comets Both V8s, P/S/, A/C
    Pneumatic Nibbler, or a Plasma Cutter
  6. scooper77515
    Can be as straight as you can make it, but I agree with the SLOW. Wear double eye protection...It costs $100 to get chunks of metal pulled out of your eyeball...wonder how I know that?
  7. blugene
    "New" snips for sheet metal. Cutting metal is what I have to do all the time, so I have several weapons of choice.:drink:
  8. ford84stepside
    Berry Alabama
    I wear glasses so I always have protection. Sounds like you learned the hard way, scooper?
  9. scooper77515
    I had goggles AND a face shield, and a chunk still found it's way in there :cry:
  10. Cleaver
    Cleaver Member
    MD
    Chel
    4-1/2 " angle grinder with one of the Thin "3/32" wheels. Actually saw Paul jr using this on American Chopper and it works great. Just like a die grinder with a abrasive wheel except about 100 times more powerful and faster. Not jumpy like a sawzall. Anything over 1/8" steel gets the gas torch broke out on it.
    Cleaver
  11. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Dang! The next step was to put a blind-fold on!
    That had to suck.
  12. Mavaholic
    Cut off wheels on electric grinders work the best, I have a 9" grinder that I put a 12" metal wheel on and it goes through anything. Its what I use for notching shock towers. Smaller stuff gets the 4" grinder.
  13. edwardsj
    edwardsj Member
    ga
    1973 maverick
  14. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Cutoff wheels, snips, mostly. If I am cutting sheet metal to make a patch I generally use some good snips to cut with. When removing sheet metal from a vehicle, I almost always use a small cutoff wheel. In the old days before I had any real tools I just always used snips, always found them to be reliable for what I want done.
    Dan
  15. mavman
    mavman Member
    Arkansas
    if it's thinner material, nibblers work great. Fast too. They'll eat aluminum up in no time especially if you're doing a backhalf floor in a race car. That stuff is usually only .040" thick.
