Cylinder Head Gasket...
Discussion in 'Technical' started by Buck62, Jun 17, 2017.
  1. Buck62
    Buck62 Member
    Chicago IL
    1974 Mercury Comet (Base)
    Right now I'm in the middle of lining up some performance mods to go on the 4.1L 250ci Automatic in my 1974 Mercury Comet. My eyes are on a re-manufactured early 80's cylinder head, as they have larger valves and more intake log cc's. Despite the fact that the engine in the Comet already runs well as it sits (it smokes the tires a bit too... stock ;)), the plan is to do the 2V conversion with an Autolite 2100 directly mounted, and possibly do a bit of porting.
    ----Here is my question----
    Because a new head is going on, I want a new gasket to replace the old one that's been sitting there for God knows how long. However, these older cars used thin steel shim gaskets, ranging anywhere from about .015" to .025" thick. Today, companies use these composite materials, which are great and all for a good seal, but they are usually double the thickness. This difference leads to a noticeable change in compression, and thus power output. I believe another thread (can't remember if it was on fordsix.com or this forum) put the difference at about .5 compression points per .020". That would be enough to make the mods mentioned above not worth it for the cash going into the project.
    I don't want to machine the head to compensate for the added thickness for cost, reliability, and time reasons, but I want to maintain what stock compression the car came with, 8.0:1 for 1974.
    To do this, I would need to find one of these steel shim gaskets. Problem is that I can't seem to find these things anywhere, and I just run into another composite gasket.
    If anyone has any idea as to where I could find the gasket, could you post a link so I can buy one?
    Thanks in advance!
  2. Powerband
    Powerband Member
    NY's \H/
    ... all 144, 170, 200 & 250ci engines came from the factory with steel shim head gaskets that have a compressed thickness of approximately .025", however these gaskets are no longer available and scarce as NOS (New Old Stock). As such, you'll need to use an aftermarket head gasket (produced by Felpro, Victor, Corteco, etc) which are composite type head gaskets that have compress thickness ranging from .040" to .055", depending on the manufacturer. Composite gaskets seal better and last longer than OEM steel shim gaskets, but to use them you'll need to mill the head to compensate for the difference in gasket thickness. To do that you need to compare the thickness of the OEM gasket that was removed, to the composite gaskets advertised compressed thickness, then mill the head accordingly. For example, if your old shim gasket had a compressed thickness of .025", and the new gasket has a compressed thickness of .050", you'll need to mill .025" off the cylinder head to maintain the same CR, more if you want to increase the C/R.
    You will see small block six head gaskets sold as fitting 144, 170, 200 and 250 cid sixes. The 144 and 170's have a cylinder bore of 3.5" and 200 and 250's haev a 3.68" bore. They are not interchangeable.
    Steel shim gaskets for the 3.5" bore 170's are available from a few vendors and other sources BUT no source of the 3.68 bore 200/250 steel shim gaskets are readily available. I have considered re-using steel gaskets I've removed from a 200 and 250's.
    Simplest ( only? ) solution is to mill the head to maintain the CR. I strongly recommend first measuring the combustion chamber volume to verify your initial projected CR or you will be guessing at multiple factors in your determination.
    https://egge.com/
    have fun
  3. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Could a steel gasket be reused if coated with a sealant like the old Indian head stuff? I'm surprised someone doesn't make a mls gasket.
  4. Buck62
    Buck62 Member
    Chicago IL
  5. rthomas771
    Do you know the price of this custom made head gasket? Might be cheaper to have your head shaved.
  6. Buck62
    Buck62 Member
    Chicago IL
    $41.99 for the gasket.
    What's the average price of milling the head?
  7. 71gold
  8. duramax59
    duramax59 Member
    Ohio
    I maybe mistaken but I believe these are steel shims and not head gaskets. They are used to correct deck height. Just my 2 cents worth.
  9. Buck62
    Buck62 Member
    Chicago IL
    Well, ultimately we decided that since the cylinder head is going to the machine shop anyway, we're going to have it milled .045 in order to compensate for the thicker composite gasket and to make a slight boost to compression.
    We think it will be a nice compliment to the Autolite 300cfm 2v carburetor and headers we're going to add, along with the electric fan and 100 amp alternator we've already purchased.
    Our intent is to add 50hp to our 250ci motor strictly with bolt-on additions. We don't want to go any higher because it opens up the proposition of becoming never-ending project of drive-train modifications and chasing more and more performance down the road. We're going to save that money for the body and paint.
  10. greasemonkey
    Sedalia,MO
    Sounds like a good plan.
  11. 71gold
    what cam are you using with this new found HP?
  12. Buck62
    Buck62 Member
    Chicago IL
    We're keeping the stock cam for now. We realize a cam would also improve performance, but we're trying to stick to our budget with bolt-on upgrades. That's the big word here.... "budget."
    But, we're open to the idea of taking the donation of a cam. :thumbs2:
  13. rthomas771
    Might want to reconsider the cam. Ford always wanted the 6 cyl to get the best mileage possible and was very conservative with the cam. With a little bit more cam it will wake up a handful of sleeping horses. While you're at it...use the pre-emission '69-'72 timing gear set. This will insure better valve timing for better performance. Ford changed the valve timing twice to get better emission numbers in these smog motors. Recurve the distributor to have full mechanical advance all in around 2000-2500 rpm. Play with the vacuum advance to deal with spark knock if needed.
    Krazy Comet likes this.
  14. Buck62
    Buck62 Member
    Chicago IL
    We're definitely planning on advancing the timing. But as far as the cam and timing gear set goes, let me reiterate what I wrote in my last post...
    Budget
    Budget
    Budget
    If we didn't have a budget, and this was solely my car, I'd be slapping a turbo, racing tranny, and a beefy rear end in the old Comet.
    But this is a father & son project, and my kid just turned 16 and only has a learner's permit. So, while I appreciate the good advice, for now're looking to...
    A: Dress up the engine a bit
    B: Improve the sound of the car
    C: Teach my kid a few basics about working on cars
    D: Get a nice burnout
    Top end speed is NOT what we want. I don't want my kid wrapping this car around a light pole. This is just a light, top end improvement for the above mentioned reasons.
    We still need to save up for the body and paint. I made a deal with my son that I would match the money he saves to invest in this car. So, we're sticking to our budget for performance upgrades.
    I've owned over 50 cars in my life and I know how quickly they can become a money pit.
    Not this time! Lol
    mojo likes this.
  15. 71gold
    " the plan is to do the 2V conversion with an Autolite 2100 directly mounted, and possibly do a bit of porting."
    all of this is useless without a cam...:yup:
    B: Improve the sound of the car...only way this can happen...302 V8
    also...you are messing with the wrong engine for a..."budget build"...JMO
    my advice...leave it stock until he has some driving skills and save up for a 302 swap.
    My Sons first car was the Maverick I now have , we had "no budget". we built the 250 that came in it $3K...then went to the 302. next was the 347 w/full race AOD. we built it "his" way, him reading books and listing to his friends. after the 347 swap I never let him drive the car again, he was also driving on a permit... I got him a S10 truck to drive...
    he learned that wanting and getting isn't always what you need...:huh:
    "His Mav." now has a fuel injected LS with a race ready 700R4 transmission...that I drive...:drive:...:chirp:
    note...my Son is 30 yrs. old now and has only had 1 ticket (@17) in a stock 4.3 (6cyl) Chevy S10...
    ticket was for...laying 200 feet of drag...LOL
